OK i want to backup my lost disks dvd shrink will only get it to 50 %
so i will make 1 to 1 copies dvd9-dvd5 problem is dvdfab wont let me it says that i can not be done
error it is a dvd9 and can not be split into 2 dvd5
but i can copy it to the hard drive
anyone know where to go from here
btw the disk is ripped to hard drive
Results 1 to 9 of 9
My brain hurts......
Use DVD Decrypter or DVDFab Decrypter and rip the Lost DVD to your hard disk. Then, use DVD Shrink to shrink the Video_TS folder that you have ripped to your hard disk. Burn your resulting Video_TS folder from DVD Shrink to any DVD+R or -R.
thanx for the help but i am very versed in the way of dvd shrink
the compression ratio sits at about 50% which is WAY to low
so i want to make 1:1 copies so i want to split the dvd9 to dvd5
dvdfab wont let me split itMy brain hurts...... -
Have a look at DVD-RB, it doesn't transcode the video it encodes the video leading to much better quality as it encodes to fit the available space
It comes with a couple of very good freeware video encoders, as well as the options to use CCE or ProCoder if you have access to those
Its slower as it encodes the video, but if final output quality is what your after, give it a look
The Pro version has more options that are not available to the freeware version, and has features well ahead of the freeware release, and only cost $10 to register, which is well worth it -
You could try shrinking, and then reshrinking one more time. put it in your player and see if the quality is acceptable to you.
Here's an old Dvdshrink trick, take i/2 of the episodes and cut them down to still images and them shrink the result. You should get all the menus and etc and 1/2 of the episodes in full woth very little comppression. Then do a second disk with the still images/full episodes reversed. label the disks appropriately and you shoule have 2 disks, each with half of the episodes in usable form and all the menus on each. This is more useable than the Dvdfab result for episodic disks. Nyah Levi
If you don't need the menus you could use DVD Shrinks in reauthor mode and just drag across half the episodes per disk.
Or, use vobblanker to remove the episodes you don't want.Read my blog here.
Originally Posted by nelson133
Cheers
Edz
A Holiday Season Shoutout To All
By budwzr in forum Off topicReplies: 15Last Post: 28th Dec 2011, 22:44 -
Stargate SG-1 Season 6 & 7 A/V Sync Problems
By slider5634 in forum DVD RippingReplies: 16Last Post: 24th Jul 2009, 18:21 -
Lost Season 2 Conversion Issues
By loggin in forum DVD RippingReplies: 17Last Post: 15th Jan 2009, 02:35 -
Problems with removing "Piracy is theft" sequence from 24 season
By Hamilton in forum DVD RippingReplies: 2Last Post: 10th Jan 2008, 20:25 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 00:23
