  1. I got a DVD+R of a video from a friend, but I can't read it on my NEC burner, which is supposed to handle almost anything. (I usually burn DVD-R's). Windows thinks there is no disk in the drive.
    I fired up Nero, and asked for Disc Info. It showed this:
    DVD Session
    |__Session 01 (2,529 MB)
        |__Track 01: Start 0 Length 31,744KB, Data (mode 1)
        |__Track 02: Start 15888 Length 2,557,888KB, Data (mode 1)
    Then I tried to copy it to an image file. I got the following messages:
    Can only copy first data track to a DVD
    Creating the image for burning
    Error reading data
    Burn process failed
    Finally, I tried copying the tracks one by one with Nero. It didn't seem to do anything when I tried track one. When I copied track two, I got a progress bar for about a minute. While it was working, I saw a growing image file on the disk. Then it stopped, and the image file disappeared (Nero erased it). I think the same thing happened with the first track, but it happened too quickly. No error messages.
    Do you thing something is wrong with the disc, or is there another tool that would be useful to copy the data? I was hoping to burn a DVD-R with the data.
    Was it made on a DVD recorder?
    If so, may not be finalized.
  3. lordsmurf may be right. I would try isobuster.
  4. Thanks, I'll give isobuster a shot. It was a copy of a VHS tape, so he might have used a DVD-Recorder, I'll ask. Is there a tool that will just finalize it without adding another session and making the movie unreadable?
    Not really, no.
    Take it back to him and have him finalize it.
    Apr 2003
    Maryland
    DVD Recorder recorded discs usually will only play in the recorder that made them unless they are finalized. Not finalizing basically allows you to to go back and record multiple sessions till it it full. At which point you usually finalize if you want to view it with another player.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
