To author a progressive DVD, what do I need to have and how do I go about accomplishing it? Can I use Adobe Encore to author a progressive DVD?
Results 1 to 20 of 20
I don't know about Adobe Encore, I don't have it. I prefere DVD-Lab.
Interlaced or Progressive, it doesn't matter. The only thing you have to worry about, is if you have Progressive that is 23.97 fps. In that case, it needs the 2:3 pulldown. If the m2v doesn't have the pulldown flags allready, DVD-Lab will do it for you.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
How did you render the files to be used on your project? If you have rendered them as progressive, your authoring application will probably prepare and burn you DVD as progressive. Sony's DVDA does that.
Cheers!
Mark -
Thank you for the response. I'll keep that in mind next time I render my footage. By the way, what is the really big advantage of progressive DVD?
Picture quality is enhanced and I can only dare to say that progressive files are better for storage since they don't have those fields coming and going all the time that can produce artifacts when you convert an interlarced file to progressive. The magic is going to work if your TV is progressive, and if you have the progressive cables, otherwise you DVD player will interlace the output so that it can be shown correctly on your regular TV (and here you won't notice absolutely any difference AT ALL). Please someone corrects me if I'm wrong. Thanks.
If the video source is interlaced (and NTSC/PAL formats are), it should stay interlaced, period; there's nothing to gain by changing it to a progressive source.
I do agree with you here, but some people like to convert their video files to MPEG4 to watch their favorite movies on the computer. So converting to progressive is a must here, otherwise the files will not be displayed correctly
Originally Posted by Cunhambebe
Sorry - I know that, but this would be one of the advantages of the progressive files (no need to deinterlace them for further usage such as converting to MPEG4) and I guess this answers one of the questions here
-if your TV is progressive you may notice the image is enhanced, and;
-what else? Hmmm -
In order to have a progressive source from interlaced video, you have to deinterlace, which always results in a decrease in quality since half of the video information is being tossed out.
After reading your responses, I really don't think you understand the concepts of interlaced and progressive video. Lordsmurf has a writeup on his website.
-NTSC, PAL and SECAM broadcast formats use interlaced video ALWAYS.
-Deinterlacing video loses quality ALWAYS.
-There is NOTHING to be gained by converting interlaced video to progressive.
-you can store the files as progressive (and later convert them to MPEG4);
-what else? Hmmm
-If creating MPEG-4 video, which is meant to be viewed on a PC, then yes, it's alright to deinterlace it, but it will lose picture quality as deinterlacing always does. Of course progressive video looks better on a PC screen because computer displays are progressive and conventional television is interlaced. Of course with MPEG-4 (or any other format), if you're changing the resolution from 480 lines to something smaller, then the interlace structure's destroyed anyway. -
Originally Posted by non-linear
1. A pure telecined NTSC film input.
IVTC can be applied to recreate the 24 fps (23.97 actually) progressive sequence than can be authored to DVD and properly played back to interlace or progressive TV sets. For progressive output, the 23.97 frames are repeated in a 3:2 sequence at 60 frames per second. For interlace playback the progressive data receives a 2:3 telecine field repeat to increase field rate to 29.97.
http://www.dvdfile.com/news/special_report/production_a_z/3_2_pulldown.htm
2. A pure PAL 50 field per second film transfer where the projector is run at 25 fps. Proper field selection can restore the 24 fps progressive sequence.
It is important to realize that progressive televisions include internal hardware deinterlacers. In order for normal analog NTSC or PAL broadcasts to be displayed on a LCD, plasma or many projection technologies, the interlaced video must first be deinterlaced and scaled in hardware to the "native raster" of the progressive display.
Computers don't have this capability built in. Instead, software display deinterlacing viewers like PowerDVD or WinDVD can be used. If you view interlaced video raw on a progressive display, you will see alternate line tear in areas of motion. This is normal.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
After reading your responses, I really don't think you understand the concepts of interlaced and progressive video. Lordsmurf has a writeup on his website (...) The picture will look like shit on any conventional television.
Thank you so much for this discussion. I learned a lot. I'll give those links some reading...however in the mean time, I like to ask this question. I have a Sony HVR-Z1U, can this camera shoot in progressive? Or I a guess another question is, how or what do I need to get true progressive footage?
Originally Posted by ljCharlie
If you transfer the HDV signal to the computer HDD over IEEE-1394, you will have 1080i. This can be downconverted to 480p with software (e.g. Premiere Pro, Vegas 6, Final Cut Pro, etc.) but the computation time will be very long on a normal computer.
Video display cards have some hardware assist for scaling but not for deinterlacing. All in all, I think you will still get a much better DVD by downscaling to 720x480i and authoring interlace.
In the future, other alternatives may emerge.Recommends: Kiva.org - Loans that change lives.
And please remember what I've said...
Progressive DVDs are going to work if you have a progressive monitor or Television. And yes, one of the advantages of progressive files is that you can store them for the future and convert them to MPEG4 without deinterlace them lol lol -
Again, thank you for the responses. I'm using Avid Xpress Pro HD. I'm guess that AVid Xpress Pro can capture at the HD level. I have not tried but read that it can. So let's say that it can, I can capture the footage in HD resolution into Avid Xpress Pro then down convert to 480p and author as progressive to DVD, correct?
I'm using Avid Xpress Pro HD. I'm guess that Avid Xpress Pro can capture at the HD level
I can capture the footage in HD resolution into Avid Xpress Pro then down convert to 480p and author as progressive to DVD, correct? -
You can but why? HDV will look better 480i than 480p as explained above. There is nothing in AVID Xpress that changes that.
Deinterlacing has quality costs and adds to encode time.
Try it both ways and see for yourself.Recommends: Kiva.org - Loans that change lives.
Thanks! I got it. Okay, here's another question. What is a better option, down convert a HDV content from the camera when capturing or capture as HDV content and then down convert to 720x480i to auther as DVD? Right now, the only advantage I see from capturing as a HDV content is that I don't have to recapture the footage again when a HD DVD or Blue Ray is available to author as high definition dvd.
Decimating a 'progressive' NTSC DVD
By beerbohm in forum Video ConversionReplies: 7Last Post: 4th Sep 2011, 10:02 -
How to progressive Upload video & progressive download
By video909 in forum Video Streaming DownloadingReplies: 1Last Post: 6th Mar 2010, 05:17 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
Can progressive video be saved as DV without losing progressive advantages?
By boblin2 in forum Video ConversionReplies: 7Last Post: 22nd Jul 2007, 14:35 -
Interlace vs progressive DVD problem...
By main.dvd in forum Authoring (DVD)Replies: 1Last Post: 18th May 2007, 08:53
