    Mar 2005
    Southeast
    I triied to use DVDRemake Pro to merge together my copy of a double sided DVD. Well the merge worked great but the menu is a problem. I don't care about the generic menu my problem is where it say "disk 1" and "disk 2" do not lead to anything. so I am stuck with a 8GB disk that I can not access the movies or the menus.
    Please advise!
    How can I get my double sided dvd's backed up on to a 8GB dvd with working menus?
    I dont care if I have to deconstruct the entire dvd as long as the completed project is a 8 GB dvd with working menus.
    Guides please and complete ones, cause I feel that the DVDRemake Pro guide was missing the step to link the movie to the text object or something.
    Thanx
  2. This was already mentioned several times in this Forum. Problem is most probably with the copy of the program you are using. Here is the copy of the post at DvdReMake forum (READ THIS FIRST before posting if you have problems with DvdReMake):
    DvdReMake (Pro) is quite stable program which can handle huge variety of differently authored DVDs. When we hear about problematic disk we investigate the problem and release a bug fix.
    Please check if you are using the latest version if you experienced a problem with DvdReMake (Pro). You can do it on the "History" page:
    DvdReMake development history
    DvdReMake Pro development history
    Please don't waste your time and time of the people on this forum posting about problems you experience with DvdReMake (Pro) if your copy of the program was not downloaded from DimadSoft.com.
    Each downloaded copy is unique and will run correctly only on the computer it was downloaded for. Original copies downloaded from DimadSoft.com will warn user when started on different computer. Copies you may find on the Net will not, they will allow you to proceed but will produce incorrect output.
