Hello,
I was wondering if anybody could help me decide which Codec I should use when coverting video files from VOB to MOV.
Here's my project:
I'm using MacTheRipper to rips scenes from DVDs (that I own) onto my computer. I am then using MPEG Streamclip to convert the VOBs into MOVs so that I can edit the scenes together in Final Cut Pro. I will then be projecting these clip collages using a high-def video projector.
MPEG Streamclip gives you tons of different Codec options when converting to MOV. JPEG-A is the default, so that's what I've been using (saving at 50% quality -- also the default). Basically, I'm looking for a recommendation about which Codec will give me decent quality without creating HUGE files.
In some cases, I'm not ripping individual scenes (chapters), I'm ripping the entire movie so that I can pull multiple clips from it. When I make a feature length MOV, saved as JPEG-A/50%, the file I get is like 10gb which seems way too big (especially since the quality isn't necessarily all that amazing).
I don't need perfect quality, just good enough to project without too much blotchiness.
Any insights would be much appreciated.
-DARNELL
DV is all you need.
Choose "File/Export to DV.../Compression: DV (DV25)".
Future versions of MPEG Streamclip may allow you to set the aspect ratio of the exported .dv -- currently it defaults to 4:3. QT Player Pro 7 has a setting for 4:3 / 16:9 so as a workaround you can re-export as 16:9 .dv, if neccessary.
http://www.sjoki.uta.fi/~shmhav/SVCD_on_a_Macintosh.html#edit_convert_MPEG -
I tried using DV files, but I found them to make FCP pretty unstable. For example, if I convert a two hour movie to a DV, then attempt to scroll through it in order to find my clips, it gets all jerky and when I try to simply play the clip, it freezes often. Whereas, with MOVs, I have no problem working off of a two hour clip.
Does this make sense to you? Should I try DV once again? Do you think I may have done something incorrectly?
Thanks for your help.
moving project from FCP to premiere: mov problems
By SwankyG in forum EditingReplies: 13Last Post: 10th Nov 2010, 00:06 -
Final Cut Pro: Converting FCP formatted .MOV to PC compatible format
By 6079 in forum Video ConversionReplies: 6Last Post: 23rd Sep 2010, 08:29 -
Self Contained FCP MOV to Mencoder H.264 Error
By skywriter in forum ffmpegX general discussionReplies: 2Last Post: 10th Feb 2010, 10:49 -
FCP missing PRORES codec
By ettin in forum EditingReplies: 0Last Post: 3rd Aug 2008, 14:54 -
VCD to MOV - no audio on FCP
By kj1983 in forum MacReplies: 3Last Post: 9th Jan 2008, 09:05
