I am going to make a VCD to be played in a stand-alone DVD player at a trade show and I want it to repeat.
I am very new to making VCD's (never done it), but I do have the appropriate hardware and have done data and audio CD's.
What software should I install to do this and how do I make a menu that has the option of repeating? Or is "repeat" built into the DVD player?
Hi !
You have to use some authoring program!
Roxio Video Pack 5 does the job including
menu, playing one clip over and over again,
letting you define the return, next, previous
keys of your remote control.
Once you get used to Video Pack it is quite
o.k. and some features come in very handy!
Good Luck
Med. -
david,
easy!
on my Apex's, you...after disk inserted into player. . .
* press the RESUME button, then
* press the the REPEAT button and keep pressing till it says,
"REPEAT - ONE" if its a single clip you want to play over and over
again.
Make sure you first at the clip you want to repeat, then
use the above steps outlined.
This is how it works for me, unless there is an easier way on the
Apex models - mine is the AD-500 and AD-1500
Save A-B repeat?
By therock003 in forum Software PlayingReplies: 1Last Post: 8th Sep 2010, 17:57 -
AVIsynth: is there such a function like repeat/until or for/next ?
By vhelp in forum EditingReplies: 4Last Post: 8th May 2010, 05:20 -
Making a short audio track repeat in the video
By Xpenguin17 in forum AudioReplies: 9Last Post: 3rd May 2010, 08:01 -
Want dvd to repeat when finished
By wauzoo in forum Authoring (DVD)Replies: 2Last Post: 26th Apr 2010, 07:53 -
A-B repeat in command line
By alexandre_fs in forum Software PlayingReplies: 4Last Post: 15th Jan 2009, 15:35
