I've got a set of VOB DVD files from an old movie which TMPGEnc DVD Author says are too large (about 4.9g) to fit on one DVD-r. Is there a way to reduce the size of the files to fit onto a DVD-r. (I am not sure if the sound is stereo or 5.1 )
Results 1 to 10 of 10
DVD Shrink. Nuff Said.
"*sigh* Warned you, we tried. Listen, you did not. Now SCREWED, we all will be!" ~Yoda -
Oog, don't do that, Shrinking something from 4.9 to 4.7 GB's should really show virtually no difference. Unless the movie is 3 hours long, then it's already compressed the hell out of, and you will notice some artifacting.
It's not 4.9-GB to 4.7-GB (4% reduction), its 4.9-GB to 4.38-GB (10.6% reduction).Originally Posted by GreyDeath
Question for you good folks. When I grab an DVD9 ISO from the web, I need to extract the VIDEO_TS folder from it because I don't have a DL burner. When I fire up DVD_Shrink to compress the DVD9 to a DVD5, I get error messages like "invalid data in such-n-such VOB" and I can't compress.Originally Posted by rkr1958
Is there a utility to fix these problem VOB files or am I SOL? Thank you. -
Doesnt shrink work with .iso images? I thought the newest did. If not, you could try mounting the .iso to a virtual drive and use shrink on it as if it was a regular dvd.
Any s/w to reduce audio dynamic range in DVD files WITHOUT demuxing first?
By EmmB in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2011, 16:22 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Reduce VOB filesize
By jacktorrance in forum Video ConversionReplies: 8Last Post: 14th Jan 2009, 12:34 -
Need to compress 5 VOB files to fit in one 4.7GB DVD...
By pmolson in forum Video ConversionReplies: 12Last Post: 20th Oct 2008, 18:52 -
how to reduce VOB quality..?
By chocolate_brownie in forum Video ConversionReplies: 7Last Post: 22nd Jul 2007, 20:22
