I'm coordinating A/V for a lego robotics event. During the event I'd like to save to hard disk all the video from 2 (maybe 3) cameras. I'm thinking of getting a couple of usb 2.0 hardware MPEG encoders - Hauppauge WinTV PVR-USB2, ADS DVD Xpress (USBAV701) ... Tight synchronization between streams is not an issue and only simple audio is needed. This is a burst application - record for about 3 minutes then we have some free time.
Does anyone have experience capturing two streams on one machine. The hardware should be fine - not clear how tested the software tools are for these consumer devices. Environment is WinXP on a 1.5 Ghz Thinkpad or 3.0 Ghz ThinkCenter.
Imaging away / flick
Hook up as many USB devices as you dare.
Find some software that allows capturing from multiple sources at the same time (gbpvr works with Hauppauge devices extremely well).
Turn off all unneeded services, and applications, so that the hard drive is NOT going to be busy doing anything but recording.
Pray that the system can sustain the data write rate needed for multiple stream writes simultaneously.Cheers, Jim
My DVDLab Guides
Capture Multiple streams to Mac
By joust888 in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2008, 11:03 -
A Good USB Capture Device?
By hech54 in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2007, 02:23 -
USB device capture
By ramin in forum Capturing and VCRReplies: 1Last Post: 15th Nov 2007, 14:48 -
capture device: usb or pci?
By danica in forum Capturing and VCRReplies: 2Last Post: 5th Sep 2007, 12:04 -
USB Capture Device
By gruberted in forum Capturing and VCRReplies: 13Last Post: 11th Jul 2007, 13:56
