Hello, all--
I'm having frustrating mpeg issues. I converted an DIVX avi to a DVD standard (720X480) mpeg2 via FFMPEGX (using the ffmpeg encoder). Everything seemed to work well, and Sizzle recognizes the file fine.
DVDSP, however, does not. When I opened the file using the Quick Time 7 player, the information box says that the file is encoded at 640X480 (which I assume is the reason why DVDSP won't accept it).
Why is QT seeing a different resolution? Sizzle, FFMPEGX, and MPEGStreamclip all see the file as the standard 720x480. Is this a problem with QT7, or have I encoded the file wrong? Has anybody else had this problem? Is there something I can do to make QT and DVDSP accept the file short of re-encoding with DVDSP itself?
If anybody can shed some light here, I'd be grateful. I'm tearing my hair out....and I haven't much left.
Thanks,
Clement
pull down flags...this has been discussed many times
in the ffmpegx forum. You would use the mpeg2enc
setting rather than ffmepg to make the file 3:2 compliant
for DVD Studio Pro.
QT is the backbone for DVD Studio Pro. If QT doesn't like it,
(Q.R.E.A.M.), then DVd Studio, Final Cut, iMovie, iDVD,
will NOT."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I guess I should have mentioned that I used the mpeg2enc setting as well. Quicktime still sees the resulting file as 640x480 rather than 720X480.
I'm in the process of re-encoding using the "Set3:2" option, but QT still sees the product as 640X480.
I thought pulldown flags were about frame rate, not the resolution of the picture, or am I missing something?
In any case, still no closer to a solution....
I'll play with it more after work. Hell, I don't even want the project that bad anymore. It's more about just not letting it beat me!
-Clement -
You're not missing anything - if anything it is terryj who is slightly confused on this issue (sorry terry!)Originally Posted by Clement
Pulldown explained - http://www.hometheaterhifi.com/volume_7_4/dvd-benchmark-part-5-progressive-10-2000.html (about 1/6 of the way down the page)
DVDSP output multiple copies?
By MikieV in forum MacReplies: 10Last Post: 8th Dec 2010, 11:10 -
DVDSP Disc only plays on MAC and not my DVD player
By jandajones in forum MacReplies: 3Last Post: 1st Oct 2010, 02:30 -
Livetype tot DVDSP help
By whiff79 in forum MacReplies: 3Last Post: 14th Mar 2010, 09:23 -
DVDSP Authored DVD - Cleaning the Code for replication?
By Adam Bolt in forum MacReplies: 2Last Post: 20th Jun 2007, 02:45 -
Motion&DVDSP-Square/Rectangular Pixels
By stretchweider in forum MacReplies: 4Last Post: 5th May 2007, 17:41
