  1. Member lordhutt's Avatar
    Jun 2004
    I want to get a dvd player for my car. Not for the video however. I want one to play DVD's loaded with mp3's.
    Best Buy has one and Crutchfield has 2 that do this....one of them is the JVC KD-5100 and I can't remember the other.
    However, these only work with minus r's....I did'nt even know people still used these!!!
    Is there a DVD gigamp3 player that uses + r's in the $300 range?
    Thanks for any help.
  2. Member b1tchm4gn3t's Avatar
    Nov 2003
    Illinois, USA
    not being a smartass here...but does it matter if it plays -'s or +'s? I still burn to both all the time and both are always readily available anywhere.
    If at first you don't succeed; call it version 1.0
  3. Member lordhutt's Avatar
    Jun 2004
    I dunno....I almost walked out of Best Buy with the recorder when I started thinking. I have gone through over 1000 dvd's over the years... all being +R's and just didn't want to screw around with 2 different formats.
    And it could matter to some people because even though my recorder can handle both....many can handle only + R's ...AFAIK there are none that only record in -R.??
    Also, I already have plenty on backups on +R's that I could use....I know discs are cheap (although I believe -R's are more??) and I could make more but that is not the point.
    So, if possible I would rather buy one that does handles +R....if one exists....you would think there would be since it is the more popular format.
  4. Member b1tchm4gn3t's Avatar
    Nov 2003
    Illinois, USA
    ok...what you said makes sense if you already have alot of them burned to +'s. And when I buy dvd's here...both formats are the same price. And please tell me why you think the +'s are the most popular format?
  5. Member lordhutt's Avatar
    Jun 2004
    I just thought they were...don't have anything to back it up except that I don't know anyone that buys -r's and as far as I know ALL dvd writers support +r and not the other way around...but I may be wrong about that.
    But this is not really that important.
    I just want to know if there is a player out there that will support the +r's...if not I will probable buy the JVC I mentioned earlier.
    Thanks.
