I have ATI AIW 128 Rage 16 MB card on W2K.
I installed MMC 7.5
I have two problems.
1. Whenever I open TV, it goes to "Initialization wizard".(I already initialized). How to overcome this problem.
2. Image capture works Ok. But Recording movie gives the following error. What should i do?
*** Log Manager 0: Opened on: 12/20/2001 [16:56:16]
[16:56:16] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[16:56:17] TvDisp: StartUp: Failed to setup DTV Graph
[16:56:18] SetRecLine: Failed to Setup Record Line on Mixer Control
What should I register ?
Thanks in advance
What you have to do is start from SCRATCH
uninstall MMC 7.5 then
follow the 'how to remove' MMC 7.x from the top of this tutorial
http://www.vcdhelp.com/ATI_AIW_Guide.htm
remove all the stuff it talks about! then re-install MMC 7.5 after a reboot
seems like you got MMC 7.1 mixed up with MMC 7.5 in some way - just make sure to get rid of the previous install completely!
your pal,
Stinky -
I did the fresh 7.5 installation after formatting my HD. Anyway I go thru guide again.
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
It was a stinky situation...
By zzyzzx in forum Off topicReplies: 3Last Post: 18th Jan 2008, 15:27 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 21:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
