Hello...
I have been taking advantage of the "just" setting when dubbing on the MH30. Say I have an 90 minute show, instead of having to use the 1 hour or 2 hour setting, it's supposed to fill the DVD with the best possible quality (which in this case would be between 1 and 2 hour speed).
Someone please correct that if I'm wrong.
Anyway, my question may seem idiotic but if I intend to rip those DVDs for future authoring, am I going to have any weird issues if they've been made with the "just" setting? So far it does not seem that way, but I was a bit concerned. Any advice appreciated.
Thanks!
"Just" is similar to "Manual" but user has no control over mode/time selection. "Just" will copy your recorded on HDD video onto DVD disc "as is". If you have 90 minutes show recorded on HDD, it will be copied on DVD disc in SP mode and in the optimal variable bitrate appropriate to such mode. No, you should not have any problems/issues with ripping and authoring after.
JVC SR-DVM70US High Speed Dubbing
By sd1233 in forum DVD RippingReplies: 13Last Post: 29th Jul 2010, 14:58 -
jvc dr-mh30s problema hd
By senateur in forum DVD & Blu-ray RecordersReplies: 0Last Post: 11th Nov 2009, 06:22 -
JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD Decks
By Anonymous4 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 15:23 -
Should I BUY the Canon HG10, JVC GZ HD7 or JVC GR HD1 ??????
By thecuban in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 27th Dec 2007, 12:40 -
JVC DR-MH30S DVD-RW "No Disc" error
By snook001 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Sep 2007, 13:50
