I'd like to cut out all the junk footage from hours-worth of imported avi clips currently on my PC, and resave the chopped up good clips as avis for my clip library. I've tried Easy Video Splitter and it works, but setting the in/out split points is cumbersome, using the frame fwd/back controls.
Are there splitters that can take advantage of my ShuttlePro II and its excellent control functions?
My main NLE is Vegas 6.
Many thanks.
VirtualDubMod in DIRECT STREAM COPY mode.
@nzo
One of the virtualdub variants can be used to copy out the good bits. If you have a DV codec on your system, and plenty of disk space. I also use Scenalyzer’s “split at cursor” function. Scenalyzer full version costs $39.00 but is well worth it, in my opinion.Emray holdar naaro watt -
Thanks FulciLives & holdar.
Dead easy and accurate, preferably with jog/shuttle wheel frame-by-frame control is what I'm after, so I'm still looking.
Debugmode Wax: Can't preview or render imported video clips
By Sean O'Scare in forum EditingReplies: 0Last Post: 30th Oct 2011, 10:17 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
why Avi Clips made by Edius can not be imported to premiere
By Wael in forum MacReplies: 1Last Post: 15th Jun 2009, 05:06 -
Clips cut from DVD can't be imported into Vegas, WHY?
By dora in forum DVD RippingReplies: 4Last Post: 8th Jan 2009, 19:04 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15
