I posted a question about this.Some people said maybe its over-heating.But I cant see that bei g the case.I use multiple programs on my pc and its always on.I use winavi , aurora mpeg to dvd burner and #1 video converter.after so long into converting like avis amd mpegs to dvd the pc will reboot.I dont know whats causing this.I had k-lite codecs in and when i took them out it converted ok.Now its doing the same with the codecs out.Can you please help me on this and tell me what you would suggest a good codec pack to use and for this problem of rebooting bot to happen.I wold so much appreciate your help.
Closed Thread
I suspect it's hardware related. Conversion is CPU intensive and weak parts will fail...RAM, CPU, Power Supply or CPU. If you have more than one piece of Ram then try removing one or the other and see if it eliminates the problem.
Rebooting is not usually software."Art is making something out of nothing and selling it." - Frank Zappa
Subtitles stay too long when converting MKV to AVCHD for PS3 with tsMuxer
By WFlits in forum Video ConversionReplies: 5Last Post: 31st Oct 2010, 05:15 -
Converting a few long avi into DVD using ConvertxtoDVD
By jackwolf in forum Video ConversionReplies: 2Last Post: 29th Jul 2009, 22:05 -
SVCD2DVD v2.5 Reboots PC
By ritzchef in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 20th Mar 2009, 08:29 -
pc reboots if i touch the case
By bigmicka in forum ComputerReplies: 10Last Post: 1st Jul 2007, 05:12 -
Machine reboots itself...
By The Fred in forum ComputerReplies: 17Last Post: 12th May 2007, 17:58
