I'm trying to burn some AVI files to DVD using WinAVI 7.1 and burn them with Nero 6.6. I normally have no problems but this one batch of AVI files has been causing problems, they play fine in AVI format in Windows Media Player. Once they're converted and burned though in one section the audio is out of sync with the video for a while. And the picture gets all scrambled in some spots and occasionally freezes. I've tried encoding them several times and burning them several times using good quality Verbatim DVD discs but have problems each time. My burner is a Sony DW-Q28A and the AVI files are about 21 minutes each (6 total) and using the Divx video codec, 352 x 240, 29.97fps and a bit rate of 577kbs. The audio bitrate is 56Kbs. I'm not sure if the problem is in the encoding or burning. I've burned many other discs without problem.
I've also tried DVD Santa and just burning the one episode that is having the problem. So my question is this, why would an AVI file that plays perfect in Media Player not convert correctly to DVD?
Thanks.
Closed Thread
continue in your first topic. reply to add more information.
https://www.videohelp.com/forum/viewtopic.php?t=280871&highlight=
Problems with an avi to MKV conversion
By Paxmilitaris in forum Video ConversionReplies: 0Last Post: 21st Oct 2011, 15:11 -
DVD to avi conversion problems
By carlmart in forum Video ConversionReplies: 6Last Post: 19th Apr 2011, 15:01 -
Having problems with my .MKV conversion (to .AVI)
By triptiks in forum ffmpegX general discussionReplies: 2Last Post: 16th Jul 2008, 23:29 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 17:56 -
By olson311dude in forum Video ConversionReplies: 14Last Post: 9th Oct 2007, 05:27
