  1. Anonymous
    Guest
    how does one control new browser window size?
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Assuming IE:
    With only one window open, Resize the window the way that you want it. Hold Ctrl and click on the red X (upper right corner of window). The next time you open an IE window, it will be that size.
    Some web sites build this into their code, or have pu-ups/unders, so when you close all of the windows or turn off your PC, IE may use the Pop-up size as default.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    There's a fair bit of info regarding registry hacks to fix this in google. I found that the Ctrl and Shift combinations didn't work as well as fixing the registry keys directly.
    If in doubt, Google it.
  4. Anonymous
    Guest
    Yeah the first didnt work.Any links on the regedits?
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Oh c'mon, Gee - don't be lazy now !
    I guess I'm expecting too much, as if you had have done a google, you wouldn't be asking the question in the first place
    http://www.google.com.au/search?hl=en&q=internet+explorer+window+size&meta=
    http://www.mvps.org/winhelp2002/ResetWindowPlacement.reg
    http://www.onecomputerguy.com/reg/ie_window_size.reg
  6. Anonymous
    Guest
    I prefer talkin to the pros.Thanks.
