I am trying to convert a avi. video using TMPGEnc and the complete file comes up as only 20 mins in length and about 2 hours of black screen at the end. What do settings do i have to put to correct this problem.
Any other ways i can put it to DVD?
How did you do it? Did you use the wizard or the manual setting?
Here's a guide that should help (found in the CONVERT section on the left of the screen)
http://www.dvd-guides.com/content/view/52/59/Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Originally Posted by Clarky_man"Art is making something out of nothing and selling it." - Frank Zappa
yep, fairly common problem here.
The well-documented fix is to extract the MP3 audio to a WAV using virtualdub (or one of its variants) - these guides may assist you with this:
http://members.dodo.net.au/~jimmalenko/ExtractAudio.htm
https://www.videohelp.com/guides.php?guideid=837#837
Then you feed your AVI into TMPGEnc as your video source, and the WAV file as your audio source.
Another less documentated method that I've never tried but is alleged to work is to use the source range filter on the advanced tab, and manually select the final frame in your AVI to "hard-code" where you want it to stop. As I said, I've never tried it, but in theory it could work.If in doubt, Google it.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
