I had a request to add the option to change the Sample Freq from 44.1 to 48 using my tool - simple to do in the registry but as soon as MMC 7.5 starts up it deletes any profile that has Sample Freq of 48 KHz.
This is confusing because there are DVD presets in MMC 7.5 but the audio is set to 44.1 when the DVD standard is 48
see the specs:
http://www.mpeg.org/MPEG/DVD/Book_B/Audio.html
I've tried upping the bits from 16 to 24 also but it still instantly deletes any profile set to 48Khz ??? very strange - if someone can figure it out pass me the info - I'm puzzled by this one.
patrickm??? next?? help me out fellas!
Results 1 to 1 of 1
your pal,
Stinky
Is a 44.1 KHz audio capture OK for a compliant DVD?
By c627627 in forum Capturing and VCRReplies: 8Last Post: 23rd Mar 2010, 05:29 -
capture of S-Video and PCM 44.1 kHz at the same time ?
By nidi in forum Capturing and VCRReplies: 16Last Post: 23rd Apr 2008, 15:16 -
(Completed): MMC capture results in 44100 sample freq instead of 48000.
By palouse in forum Capturing and VCRReplies: 14Last Post: 23rd Oct 2007, 16:47 -
How to change the audio from 44100 to 48000 using Aften?
By php111 in forum AudioReplies: 13Last Post: 2nd Oct 2007, 20:58 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 03:28
