    Feb 2004
    Canada
    Hey all my question is pretty much exactly what the Subject says i made 2 dvd folders with dvd santa and each are only 2.2gigs so i was wondering if there was a way to burn both folders to one dvd. So far every program i use will only let me load one folder so if anyone can help me out PLZ reply thanks!!!
  2. Disgustipated TooLFooL's Avatar
    Feb 2004
    Opium Den
    are they 'movie-only's or are they full dvd's with menu's and all?
    I am just a worthless liar,
    I am just an imbecil
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If you want to create your own custom menus, TMPGEnc DVD Author can do it. Just use the "Add DVD-Video" option then select your first VIDEO_TS folder, then select the title you wish to import. Repeat for each title, then do the same for your second VIDEO_TS folder and each title within it.
    If you want to retain all existing menus then DVDRemake Pro is your best bet IMO. All you need to do is open both folders as seperate assests, then go to Tools > Merge DVDs. This will place a top-menu that gives you the option of going to either individual menu.
    If in doubt, Google it.
  4. If you don't need menus use DVDShrink->Re-author or Nero Recode.
    Feb 2004
    Canada
    Well so far everything is working good but the subtitles wont work they come up but its nothing but a bunch of zero's and dashes. i dont know much about ripping subs from .mkv files so i might have messed up anymore info would rock thanks !!!!!
