Hey guys, I have a question.
I have a bunch of old Transformers episodes which I want to put on to DVD. The problem is that they're in three different formats: .avi, .mpg, and .wmv.
I want to be able to cram around 10 episodes per DVD seeing as how the source quality is pretty low (around 100 MB each episode) so there's no point in using too high of a audio/video bitrate (I'm thinking 2000 kbits for video, 64 kbits for audio).
So is there a program that'll let me convert all three formats to MPEG2 and allow me to set the resolution, video bitrate, and audio bitrate? I tried TMPGEnc but with that, the minimum audio bitrate you can use is ~1500 kbit/s which is just too much.
Also, what's a good, simple, and free DVD authoring program?
Any and all help will be appreciated. Thanks.
That's only if you use PCM audio. I'd suggest you test your DVD player for compatibility with MP2, or otherwise convert to 2ch AC3 with ffmpeggui, belight, besweet etc etc.Originally Posted by fyreboltx3
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm tells you all you need to know about the process.
IFOEdit, gui for dvdauthor, dvdauthorgui .... and the top few here: https://www.videohelp.com/tools?listuser=&orderby=Type&s=2#2Originally Posted by fyreboltx3If in doubt, Google it. -
VSO Software DiVXtoDVD is probably a good product for you to "try". I say "try" b/c it isn't free, though there is a free 'trial' version you can use (the trial version will put a watermark on the output).
Despite its name, it converts just about ANY video format to DVD compliant files. Give the trial a shot. You may find it does what you need without much fuss, which can mean a LOT compared to the trouble you may encounter using a myriad of other programs.
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 05:39 -
Converting Home Movies (multiple formats) to x.264
By llmercll in forum Video ConversionReplies: 12Last Post: 24th Nov 2010, 11:42 -
Converting MPEG2 to other formats
By hasanali00 in forum Video ConversionReplies: 3Last Post: 11th Mar 2009, 17:24 -
Converting multiple formats to WMV
By StrangeSolutions in forum Video ConversionReplies: 5Last Post: 9th Dec 2008, 20:43 -
editing with multiple formats
By abadifilms in forum MacReplies: 1Last Post: 15th Sep 2008, 14:59
