Is there any mpeg encoder that can figure out and encoder a target file in the same bitrate as the source one?
Use biterate viewer to see what the biterate is, then set your encode accordingly. As far as I know, there is no program out there that can do it automatically.
It doesn't really matter though, you're still making a copy of a copy so you will have *some* quality degredation happening. If it's size you're concerned with, use biterate calculator to determine what rate to set.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Good avi encoder?
By The.King in forum Newbie / General discussionsReplies: 5Last Post: 15th May 2010, 11:33 -
Reccomend a good 5.1 decoder/encoder software
By 1980sumthin in forum AudioReplies: 2Last Post: 25th Jun 2009, 18:47 -
Blackmagic Design - Good encoder ?
By CoNiO in forum Capturing and VCRReplies: 2Last Post: 24th Jun 2009, 13:29 -
Fastest but good quality mpeg-2 encoder
By cd090580 in forum Video ConversionReplies: 12Last Post: 23rd Jun 2007, 11:42
