Was wondering if someone could\would recommend a video card with TV out. I am looking to play movies from the Computer to the TV.
Anyone??
Almost all of them from ATI or Nvidea.
Make sure it has a S-Video out.
A computer still makes a rather poor DVD player. Expensive cards and adapters are needed for progressive 480p DVD playback or HDTV.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
TowerNS:
It helps to fill out a computer profile for users to read, in answering your questions. Although the Radeon 9xxx AiW videocards are "said" to work on rigs running @ 700 mhz or less, optimal playback of DVD's through your monitor will show dropped/distorted frames and choppy audio when processed at less than 900 mhz. If you choose to play DVD's through the "TV-out" (A/V out adapter on the Radeon cards), you will need an S-video in-jack or composite video (RCA) in-jacks on the back of your TV to enable PC-to-TV viewing. The digitized signal sent by a vid card to the monitor can't be recognized by a TV. That signal has to be sent in analog through an A/V out jack on the back of the card (via an adapter which you get with the Radeon All in Wonder).
What video cards support S-Video & Composite output over VGA via adapters?
By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 22:57 -
Video cards with Composite video out and Mandriva
By neftv in forum LinuxReplies: 3Last Post: 24th Jan 2010, 04:25 -
Video Cards???
By HotDamn! in forum ComputerReplies: 5Last Post: 7th Dec 2009, 20:34 -
Video cards
By zinc in forum ComputerReplies: 14Last Post: 26th Jul 2008, 15:47 -
Video Cards and S-Vid TV out
By Vertuas in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2008, 09:36
