Hi all, I added a pioneer DVR-110D(FW 1.22) to my system. So I now have the 108 and the 110D which are setup on seperate IDE channels.
I burned a verbatim DVD-R DL with DVDDecrypter and the 110D and it choked about 40% through the burn(I've burned many Mitsubishi DVD+R DL without a prob(on the 108) but this was my first DVD-R DL). Is this because DVDDecrypter does not support DVD-R DL? or just a bad disc? I have another disk but I wanted to rule out incompatibility first before I try again.
Also I've burnt tons of DVD-R SL with DVDDecrypter and have been very happy with the program(its a shame about what happened with it), but I want to be able to burn 2 DVD-R SL discs at the same time. Is there a way DVDDecrypter can do this?
So what I want is a program to support DVD-R DL and Multiple burning at once.
I dont like Nero for dvd burning, but I have version 6 which I use for all CD burning, so this would be a last resort.
cheers![]()
Can't understand why your version of NERO would not support your needs. Mine does and mine can do 7 burners at once (of course with the paid option). Decrypter won't support what you want to do. Do a Google search. Cheers!
I've searched but most applications dont state if they can do these things in their advertising. I'm sure Nero could do multi burns but I've had bad results with nero in the past with dvd burning so Im hesitant to use it, and I dont think V6 handles DVD-R DL.
Are there any other progs that support this?
cheers -
Take a look at Gear Pro 7. It says it can do multiple burners and DL. http://gearsoftware.com/products/gearproprofessional.cfm
Thanks redwudz, thats the sort of thing Im looking for. Its not listed in the tools section, has anyone used it? Also do you know if it can handle pdi images?
cheers
Author/burn software which burns many mpgs in < time than Win DVD Maker
By wetcamelfood in forum Newbie / General discussionsReplies: 2Last Post: 9th Jul 2011, 11:09 -
burn 2 dvds at the same time.
By dymx in forum DVD & Blu-ray WritersReplies: 8Last Post: 12th Dec 2008, 16:58 -
Burn 3 DVDs at a time
By Dimava in forum DVD & Blu-ray WritersReplies: 42Last Post: 5th Aug 2008, 15:31 -
**Help! Need to burn a DVD and running out of time to do it!**
By catdrummond in forum Newbie / General discussionsReplies: 1Last Post: 19th Oct 2007, 07:53 -
By catdrummond in forum DVD RippingReplies: 1Last Post: 19th Oct 2007, 07:51
