i have a catalog containing .bin and .cue files how do i convert thease to play on a dvdplayer and what program can i use to do this
i have the same pproblem with .mpg and dvd rip extensions
i'm a newbie to dvd burning so any help will be most welcome
thank you
shoda![]()
What's in the bin files, mpg, avi's? TBH these questions have been asked millions of times, try the search function
He's a liar and a murderer, and I say that with all due respect. -
if the bin/cue is svcd or vcd use svcd2dvd, it can convert the bin/cue directly to a dvd.
mpgs do you author to a dvd with for example tmpgenc dvd author. if tmpgenc dvd author complain about the mpg convert it(read below here)
avis or mpgs that are not dvd compliant, divxtodvd.
and PLEASE try the search function...search for bin cue and you will get several useful tips. -
nero can also burn these to disc. the disc will contain what is inside the bin file (after it is burnt). when you burn using nero you need to select "burn image" option and point it to the .cue file;
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
