Rookie question that I couldn't find on past posts. I've captured several of my family 8mm tapes (2 hour per tape) as wmv (640X480) files using Pyro a/v, edited them (added titles, scenes) and burned them to a DVD using Premiere 1.0. Can I increase the quality (i.e. by capturing as MPEG2 or avi) but still get a 2 hour tape onto a DVD?
definetly..
i would suggest capturing to a loseless codec (mjpeg, huffyuv, etc), editing out what you dont want from the capture, and then convert to an dvd-spec mpeg.. then author.
wmv is probably the worst you could have captured to, except maybe real media.
From 8mm tape to Final Cut...no camcorder
By cecile in forum Capturing and VCRReplies: 18Last Post: 23rd Aug 2011, 23:53 -
What program/settings should I use to capture a home-made 8mm tape? (UK)
By kingmustard123 in forum EditingReplies: 2Last Post: 7th Aug 2011, 12:14 -
8mm tape source filmed twice
By Dieu in forum EditingReplies: 9Last Post: 17th Nov 2009, 20:14 -
Will a Digital 8 camcorder read 8mm tape?
By Tenacguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jun 2009, 14:24 -
8mm camcorder tape playback suggestions?
By Bix in forum RestorationReplies: 8Last Post: 23rd Aug 2008, 02:02
