I'm using TMPGenc 3.0 Xpress to convert Windows Media Center TV files to usable DVD file format. I've noticed that sometimes teh conversion leaves my video and audio out of sync. Sometimes it works just fine. I can't seem to pinpoint what causes this sync problem. You'd think it would happen with all or non of the conversions? I usually convert at night when I'm not doing anything else on the PC so it shouldn't be a resource problem while converting. Anyone else have any ideas or fixes?
Ooops! Forgot one process that does run every night along with these conversions. It's a hard drive defragger O&O. I believe it's a memory hog too. Could that be my problem? I turned it off so I'll see if it makes it better.
Defragging the HD while encoding? Yes, that should cause a few problems.
BTW, I can't imagine why you would need that much defragging. You are probably going to wear out your HD prematurely before it gets much fragmentation.
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 06:27 -
Problem with TMPGEnc Xpress 4
By milindb1 in forum Video ConversionReplies: 1Last Post: 20th Aug 2008, 04:43 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc 3.0 Xpress problem
By adamthered in forum Video ConversionReplies: 2Last Post: 7th Jul 2007, 18:22 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 15:10
