Results 1 to 12 of 12
    May 2003
    Oz
    I have some retail DVDs with volume long volume labels like for example "LOTR_RETURN_OF_THE_KING_D1"
    When I try to duplicate that in Nero it gets truncated at _OF
    Nothing I do will allow me to get a longer volume name with Nero. How can I get long volume names like these on DVDs burnt with Nero?
    Nero sucks. This is one of it's flaws that started with version 6. I hate it too, stupid ass programmers made a mistake and after a year it's still not fixed. It really kind of angers me when I think about it.
    Long names are supported on UDF and UDF/ISO, Nero is the one with the problem here.
    May 2003
    Oz
    Thanks. I thought it might have been an issue with Nero actually. I don't think it's a big enough issue to say that "Nero sucks" though. Guess I'll have to go and download that v7 Ultra edition of Nero now to see if it's been fixed.
    Cheers.
  4. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Nero 7 will be released around 13 October (according to their website), so you will have to wait until then for the download. In the meantime, you can try an alternative burning software.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    DVD-ROM (ISO):
    DVD-ROM (UDF):
    DVD-ROM (UDF/ISO):
    As you can see, Joliet only allows 16 characters, but ISO 9660 allows 32 characters. You can do this on all three DVD templates.
    If in doubt, Google it.
    May 2003
    Oz
    Originally Posted by waheed
    Nero 7 will be released around 13 October (according to their website).
    Well, through official channels it is yes.
    May 2003
    Oz
    Originally Posted by jimmalenko
    DVD-ROM (ISO):
    DVD-ROM (UDF):
    DVD-ROM (UDF/ISO):
    When I add a conventional AUDIO_TS / VIDEO_TS set of VOBs to those type of compilations I get a warning from Nero saying that I'm about to make a non-compliant DVD-Video disc which won't play in a standalone DVD player and that if I want that I should use the DVD-Video disc option.
    Use the DVD-Video option and you can't have the long filenames anymore.
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    DVD-Video:
    32 characters there too
  9. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Jimmalenko, try clicking on the New tab and see what happens to the characters for the compilation.
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Interesting ...
    Clicked New and got the following:
    ... but even more interesting, I right-clicked on the Label, went to Properties and got the following:
    Of course you could always output to the Image Recorder, create an nrg file, then use DVDDecrypter and go to Tools > ISO > Change Volume Label, and change it there:
    May 2003
    Oz
    And I'm sorry to have to report that if you hoped this little issue was going to be resolved with the upcoming release of Nero 7 then I'm afraid you're going to be disappointed
    You are in breach of the forum rules and are being issued with a formal warning. This is unreleased software. In other words, warez.
    / Moderator lordsmurf
  12. I used to hate it when I was burning mp3 CD's. I used folders for the different artists. When I had one with a long filename (even tho it was less than 100 chararcters), if I didn't go thru each folder and check them, Nero would truncate them - starting with the .mp3 extension. If I didn't check I had a CD with mp3's that wouldn't play.
