    May 2002
    i have been trying all night and besweet always says that the source is 48 when it is 44.1. does anyone know of a way to get the audio out with besweet as i would like to do this in a batch when i am not at my computer. i am not opposed to using something other than besweet as long as it can either be batched or is command line, free is another criteria.
    please help me out
    -Syco54645
  2. Member daamon's Avatar
    Melbourne, Oz
    Look into VirtualDub - I don't know if it can be batched or run from command line, but it is free.
    You don't say what audio format you're aiming for, so it's a little difficult to help more...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Use virtualdub, its "Job Control" feature (batching), and this guide
    If in doubt, Google it.
    May 2002
    mp3 or wav. i know of virtualdub, i have been sing it for years, but i would like to batch
    -Syco54645
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    May 2002
    i was unaware that it could batch and i missed that reply at 6 am. thanks jimmalenko
    -Syco54645
