I want to be able to put two dvd movies onto one dvdr then when i insert the movie into my stand alone dvd player I can ick what movie I want to watch instead of having to fast forward the first one if I wanted to view the second as i used dvd shrink re-author and got two movies on one disk but wasnt able to pick what movie I wanted to watch as I would have to fast forward to the next movie with dvd shrink re-author.I would like to know is there something i could use with the same idea except with a menu on the screen when i put the disk in can you please help.
Use DVDAuthorgui and add a simple menu instead.
Quality is my policy. -
You can still use DVDShrink to re-author both your movies to the one disc, and then use TMPGEnc DVD Author to import each titleset in as its own track, create a menu, output and burn.
... or you could import directly into TMPGEnc DVD Author, bypassing the DVDShrink step if you wish.If in doubt, Google it.
Movies, songs and other stuff with a menu ?
By gotfrag in forum Authoring (DVD)Replies: 4Last Post: 11th Jul 2009, 02:13 -
Recreate DVDR menu or edit code?
By ScannerWA in forum Authoring (DVD)Replies: 4Last Post: 24th Oct 2008, 16:54 -
Camcorder for taking home movies how to pick one!
By fishtk75 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 23rd Apr 2008, 15:28 -
edit Vob files in DVDR movies?
By SUPERIOR in forum Newbie / General discussionsReplies: 6Last Post: 12th Feb 2008, 12:12 -
Philips DVDR 3390 won't let me fast forward DivX movies
By guiri in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Sep 2007, 04:28
