Hello. I have a problem with the audio getting out of sync when I put 2 movies on a DVD. The first movie is the one that usually goes out of sync. The second seems fine in both cases. I am going to try and put the same movie on one dvd and see if it goes out of sync. I had the prior version...the beta version...and it very rarely had sync problems. I don't see that version available for download anymore. Is there something that I am doing wrong?
What type of asset is it?
It's a two part SVCD...Mpeg2 . I just finished encoding it by itself and its way out of sync again. So, there goes my theory about the two movies having an effect on the audio sync. Like I said I rarely had problems with the beta version. Any ideas what could be causing this?
Can i see your log please? Either email or post it here.
I deleted it ....I'm going to try encoding again and then I will send it to you. I have a family function to go to today so...I'm going to encode and then send it to you when I get home tonight.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
