Hello out there,
to the initiated it may seem ridiculous,but I have started recently to use Vegas on my VHS captures. My problem: I started a new project, played around a bit with FX effects and now the effect seems to be "burned-in", that is (it is the pan/crop function) although
- I closed the project without saving,
- removed the reference-files for the respective video-files (*.sfk-extension)
- even cleared "prerendered files" to make sure (in fact I hadn't done any)
- and started a new project, the panning/cropping in the respective files is still retained! The original files are unchanged, but I cannot remove this setting... How come? What do I have to change, delete, set-up?
Strange - and I couldn't find any hint in the online-help-file. Perhabs I would find something, if I knew exactly what term to look for...![]()
Any suggestions will be highly appreciated.
Results 1 to 28 of 28
That's pretty curious. Go into Preferences, General and unclick "Automatically open last project on startup". That should start Vegas without loading a project. Then start a brand new project from scratch. Other than that, I'm trying to duplicate the behavior that you've observed and so far I haven't been successful.
Great, getting so many answers in that short interval. Here goes:
I DID disable the "Automatically start last project on start-up", I DID start my project from scratch, 4 times at least, but the problem remains... I deleted the *.sfk-extensions, etc. I tried the Strg+Shift during start-up, but the problem remains. (Have to check yet, if settings are back to default...) Is there any other cache or something, that I should delete to start really and truly from scratch? I opened a new project this morning (over here it is 9 am.) - and - s.a.
Here the second screenshot:
(Look out for the borders, esp. left and right of the picture...)
[EDIT: for ease of use I changed the image to smaller version.]
You are talking about the Tittle Safe area and action Safe.? This is normal.
No, I don't mean those nice little white dotted lines. It is the black border left and right, I do not get it with the other files and did not get it in the first place...
Shall I include an additional screenshot of the "un"-bordered file(s)? Or try Sony's customer-support...is it a bug, perhabs...? -
(Last two posts were crossing...)
Also: in this same project the added files are sometimes shown with and sometimes without that border. -
Originally Posted by canadateck
. You mean the 'bug'-idea? Not to worry about it?
Set the right settings and you wont see this. Also when you render out just make sure to set the right Aspect Ratio.
I did, only as I am in PAL-land, I would chose the PAL-settings...
By the way, thanks for taking the time and trouble!
So these borders are just there for "fun"...? I wanted to add borders ultimately, to correct the TV-overscan slightly. BUT I want to see and add them when I like... -
You wont see the Overscan when Played on a TV.
They are there because of your Project settings. Title Safe and Action safe are there for other reasons, Captions,Lower Thirds and other things. -
I know.
I mean, "see" them on Vegas's screen, add them there the way I want, as I already worked out I HAVE to add small borders, to prevent too much overscan, after capturing my VHS-movies and burning them to DVD.
I'd like to get this clear: I don't mind those white dotted lines, at all, I know how to turn them on/off. I mean the borders on the left and right of the video, with some files they are there, with some they are not, and in the same video-track/same project! 8) -
Worked it OUT!!!
Right-clicking on the file IN the track brings up another window, under the "Media"-tab you may set the properties of the file, like this:
Here you see the setting for the "bordered"-version:
I'll presently include the second file for the "un"-bordered version - and @canadateck: you were right in a sense, only it is NOT the project-properties, but the FILE-properties, that have to b changed.
Anyway, thanks for all the help. -
What is the resolution of the captured file ?
If you have the top and bottom borders in the capture file (which I suspect you do), Vegas may have to pillar box to make it fit your selected project resolution. Perhaps you need to just zoom in some to fill out the screen.
Personally, I believe this file doesn't need to be adjusted for overscan, as you would not have seen the ends on your VHS version anyway, so you are not actually missing anything by leaving it as it (assuming you fix this current issue).Read my blog here.
Well, I had try-outs with previous captures, adding small black borders and not adding them, and on my TV it defnitely makes a difference. My "point-of-reference" is the station's logo. The VHS version (watched with VCR) displays that logo more or less at the exact position it is displayed during broadcast. But my DVDs had this very noticable difference, the logo having moved very near the outside (or even partly 'moved into' oblivion) of the TV-screen. *
So far I used AviSynth to add small borders and resize the orginal 720x576-capture (PAL) to something smaller, make borders of ~ 20 pixels wide - and I am happy.
I try Vegas, because I think the color correction-filters are more extensive, and I like to see the effects on this capture.
["What is the resolution of the captured file ?" -> 720x576]
* This makes for a strange effect in close-ups, when movie is scanned/panned by the broadcasting station and with the overscan poeple's faces get really quite large on the TV screen... -
Read my blog here.
Thanks, I tried that out already, really nice piece of work, but with the project I just started, it would have taken about 30 hours to frameserve/render the file from Vegas>DebugMode Frameserver>Canopus ProCoder 2.
For the time being I am yet looking for a faster possibility - correcting the colors as is possible in Vegas, use ProCoder and still finish the project in a reasonable time... I like AviSynth very much, but have not yet found the wealth of color correcting features I found in Vegas.
Perhabs I'll post in the AviSynth-forum about this.
Sony Vegas 8.0 Cookie Cutter: Border Problem
By Fairy_xo in forum EditingReplies: 5Last Post: 22nd Feb 2009, 16:36 -
can i remove black border from dvd movie ?
By rgulian in forum EditingReplies: 6Last Post: 7th Feb 2009, 07:25 -
How to remove the black border using TMPGEnc 4.0 Express
By leinan in forum Newbie / General discussionsReplies: 1Last Post: 9th Mar 2008, 07:42 -
Poor resolution of pan and zoom (Ken Burns effect)
By hemphillguy in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 16:01 -
Remove noise from VHS bottom border
By roglopes in forum Capturing and VCRReplies: 10Last Post: 21st Jun 2007, 14:36
