Hi,
I posted this some time ago. Just a follow up on the
actions I have taken.
I have tried using SSRC to convert the WAV file from Virtual Dub before converting to mp2 using toolame externally but toolame still gives me the same error
mentioned below....sigh.
I have this problem with toolame:
Everytime I use toolame whether
1. integrated with TMPGEnc
2. externally using toolame GUI
3. converting my audio into wav using VirtualDub, resample to 44KHZ and then using the resampled wav file for encoding via toolame.
I get this message at the end of the encoding in the
MS-DOS screen:
"Insufficient PCM Input for 1 frame - filling out with zeros
Hit end of audio data"
and then some statistics would appear with bit rate 224
Following that:
TMPGEnc will continue to encode as per normal.
I hear the sound too but the quality is about the same
as without toolame so I suspect TMPGEnc continues to
encode the audio using its internal encoder.
Does this error message with toolame always appear?
Hope some expert can help me with this.
well here is another suggestion but it is not a freeware program......i suggest you use MVP by QDesign it is a audio encoder and downsampler altogether it is the fastest encoder Mp2 encoder i highly recommend it but it is NOT FREE
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
