ive done this a zillion times on my old comp, i tried to do it on my new comp using xp, i go to mpeg tools, merge & cut,select mpeg-1 video cd, add my file , double click on it , pick my start and finish and select run, it tells me cant creat file.............i cant figure out why
Maybe upload a screenshot of the exact error TMPGEnc gives you ?
How do I upload screenshots ?
Your MPEG is definitely MPEG-1 ?
https://www.videohelp.com/play.htm#identify
Use the latest GSpot Beta (2.52) to check the specs of your MPEG file.If in doubt, Google it. -
Check your environmental settings: In general tab - that your temp directory is selected and there's room in it, in cpu tab - that the first 4 boxes are checked.
I'm assuming the file plays ok without audio sync issues?
I'm also assuming you've successfully converted this file with tmpgenc on the new computer rather than the old? -
You must click browse and select where to save the new file or type in the harddrive partition like:
c:\test.mpg
just
test.mpg
wont work. -
that was it, i had to click browse and select spot for it, i dont remember having to do that on 98se................
Aegisub wont play mpg, converting using divxland causes problems
By denadel in forum SubtitleReplies: 2Last Post: 2nd Oct 2011, 04:36 -
TMPGEnc DVD Author 3 (Chapter Split In two)
By GeorgeD123 in forum Authoring (DVD)Replies: 2Last Post: 13th May 2010, 20:44 -
Split 720P MPG File
By ap0091 in forum Video ConversionReplies: 2Last Post: 30th Aug 2008, 12:51 -
How to split a MPG file in specific parts
By bosstone75 in forum Newbie / General discussionsReplies: 8Last Post: 28th Nov 2007, 13:38 -
Want to capture Right side of Split-Screen mpg clip from Woodstock movie.
By quark258 in forum Newbie / General discussionsReplies: 15Last Post: 19th Oct 2007, 05:12
