    Aug 2005
    Montreal
    Hello,
    I have somme divx video file, but it lost the audio could someone knows how to fix ?
    H
    Dec 2004
    Australia
    Where was the last place you remember seeing it?
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    lol...that's just great
    Sounds like a codec issue, check the file with AVIcodec or gspot to see which codec is required, then verify you have that codec installed.
    Google is your Friend
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    https://www.videohelp.com/play.htm#identify
    Work out what codec your audio uses, and see if you have that codec. If not, download the codec.
    If in doubt, Google it.
    Dec 2004
    Australia
    I read somewhere that DivX specs only allow for mp3 audio and windows comes with an mp3 decoder. Anyone tried muxing different audio via say fuse? I guess it should support at least AC3?
    Most of the time when people say they lost audio, they mean they are converting from one format to another and that the audio was lost somewhere during the process. No mention of that here though, in fact hardly any details, which is why I posted my first reply.
