when i try to burn something, it fails and i get the error message 'buffer too large' ... iv tried diffrent media and diffrent apps to burn ( nero and alcohol) but it still fails... also iv tried to update my firmware but i cant for some reason lol
can anyone offer any help?
cheers
Things you can try:
Make sure your drives are in DMA mode
Make sure ASPI layer is installed and working properly
Set the drive as Secondary/Master (alone if possible, drive conflict)
Then try these after the above are verified:
Install latest firmware
Install latest Nero
Check your media with dvd identifier or dvdinfopro and check it against the list of media codes here: http://www.digitalfaq.com/media/dvdmedia.htm
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
Does SATA make big difference for DVD burner?
By sdsumike619 in forum ComputerReplies: 6Last Post: 28th Nov 2008, 20:21 -
DVD burner problems
By coody in forum DVD RippingReplies: 5Last Post: 12th Sep 2008, 01:18 -
Problems with DVD Burner
By poppy56 in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jan 2008, 23:48 -
Laptop DVD Burner Playback problems
By Cake^^ in forum DVD & Blu-ray WritersReplies: 3Last Post: 11th Jan 2008, 06:48
