I had an audio sync problem when I imported a long video clip.
I managed to get round the problem by importing titles using Nero Recode. (dont quite know how I managed it!)
After IŽd edited the clip and exported it, it had a sync problem again.
The file was quite large, 14mins long. Does anyone have the same problem or know exactly how to avoid it.
What software/hardware did you use to import? Did you play the captured (imported file) to see if it is in sync to start with? Is your HD defragged? Have you shutdown unnecessary background tasks before encoding?
Rob -
Its strange, it didnt do it on the smaller clips only on the big one. I used Nero Vision to import the clips and they were out of sync.
Haven't defragged but will try. There are hardly any background apps running.
It really just seemed to be the size of the clip.
(High quality PAL. 959MB)
FLV Import/Export Nellymoser audio - Adobe Premiere CS4
By shagen in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2008, 18:38 -
No audio sound on DVDs using Nero Vision 5.3.3.0
By dweis in forum Authoring (DVD)Replies: 9Last Post: 25th Jun 2008, 19:06 -
Recording audio with Nero Vision 4 Express
By SEE_Studios in forum AudioReplies: 3Last Post: 21st Jan 2008, 16:28 -
I moderately dislike Nero Vision (audio sync)
By Matth3w in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2007, 20:53 -
Nero Vision 5 menu audio help?
By sls-sls in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2007, 13:26
