I have some avi files encoded with xvid. I burned them as data and tried to play it in my dvd and nothing. it didnt recognize the disk. I know my dvd supports avi files. What am i doing wrong? can someone help me out? TY in advance
Closed Thread
Results 1 to 10 of 10
mlo356:
Check down the newbie list:
https://www.videohelp.com/forum/viewtopic.php?t=280452
Have you tried encoding @ 352 x 240 res?
QPEL ? GMC ?
https://www.videohelp.com/guides.php?guideid=810&howtoselect=4;13#810
https://www.videohelp.com/guides.php?guideid=811&howtoselect=4;13#811
https://www.videohelp.com/tools?tool=AVI_ReComp
What DVD player do you have ?
What media you burning to ?
Does your player support the media you're using ?
More info required.If in doubt, Google it.
Don't get fooled. The avi may have been converted by the program you used to burn it.
It must be a very new model. Does it say divx certified. I have had 3 older Apex and none played avi. Some models do play mpg files directly without authoring. If you used Nero to burn it may have converted the avi to mpeg without you noticing.
Please provide the exact model number of the Apex to see if it really plays avi.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
