I want to back up one of my older DVDs that had a side A and a side B. The movie is about 7.5GB I want to put it on to a 8.5GB DVD. Both side of the disk have there own chapter menus. I would like to merge the menus and two sides of the DVD so that it will work as a single sided dvd with chapter menus.
Can I do this with DVDLab pro or some other tool? If so how? Guides please.
Decompile and re-author.
The only other option might be DVD REMAKE PRO where you can take two discs and merge them into one. But you get a menu to pick the disc when started. It doesn't merge menus.Want my help? Ask here! (not via PM!)
There were a few guides on how to do this.
Google is your Friend
Merge 2 FLV video files side by side
By zsuppguy in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2010, 17:58 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
