I've loaded 7 avi assets and then click 'Make DVD & Choose menu/burning Options' button and get 'No titlesets to author' error. How do you make this thing go?
3 GHz P4 w 1GB RAM W2K on Giga-byte GA-8K-NXP w ATI AIW 9800
"Make DVD" requires that you setup your TitleSets manually.
"Quick DVD" will create a TitleSet structure for you based on filenames and file location(i.e. what folder your assets are in)
See the on line demo movies for examples of both.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
Why MPCHC doesn't show up in the right-click submenu ?
By mahogany in forum Software PlayingReplies: 7Last Post: 12th Dec 2010, 17:23 -
ffmpeg doesn't work at all
By Paulo2009 in forum ffmpegX general discussionReplies: 27Last Post: 5th Aug 2009, 00:55 -
Tmpgnc doesn't work
By better life in forum Authoring (VCD/SVCD)Replies: 3Last Post: 27th Nov 2008, 22:29 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58
