I downloaded HBO's Rome, episode 4, from alt.binaries.hdtv (1080i). File size was 4.2 GB. This was processed with versiom 0.3 and viewed on a 42" plasma screen. The video quality was fantastic!! Thank you, Chrissy Boy.
However, there were occasional discontinuities. This was never noticable in the audio but was in the video when there was movement on the screen. It occured both in my DVD player and on my computer.
Other observations:
Resulting DVD size was 2.98 GB from original 4.2 GB download
Settings tab only gives Shutdown and Options>Shutdown, Force and Force If Hung
Make DVD tab immediately starts the processing.
I realize this is a stripped down program but is this as it should be?
Once again, Thanks for this tool, Chrissy Boy
I would like to know more about your "discontinuites"...
Its all to do with duration. Input & output has the same duration but your input has a higer bitrate (usually 15000kbs+ for HDTV compared to 7800kbs which is the default for HDTV2DVD). Thus the input is bigger that the output.Resulting DVD size was 2.98 GB from original 4.2 GB download
You would only fill up the DVD if you had a longer source....
Correct.Settings tab only gives Shutdown and Options>Shutdown, Force and Force If Hung
Make DVD tab immediately starts the processing.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I guess missing frames would have been a better description. A character would be walking and suddenly appear ahead of where his step would have taken him.
It appears that the problem was a quirky disk or player, NOT the program.
HDTV2DVD 0.4 Vista
By CathyT in forum Authoring (DVD)Replies: 2Last Post: 28th Dec 2009, 13:01 -
HDTV2DVD does not load up TS-file
By feilofix in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2008, 14:25 -
New Tool: HDTV2DVD
By ChrissyBoy in forum SVCD2DVD & VOB2MPGReplies: 270Last Post: 2nd Jul 2008, 23:05 -
HDTV2DVD - .TS wont load
By NotSoEasy in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 15th Mar 2008, 20:09 -
How to load .ts file into HDTV2DVD?
By JR.S in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 02:59
