...or After Effects 6.5.
I'm just getting into adding a few special effects in my video projects. And this one is proving to be a bit more difficult than I thought.
I've been searching for tutorials, but no luck so far.
Does anyone have any advice?
Results 1 to 10 of 10
the fat man is back!!
Try here http://www.digieffects.com/products.shtml
Google After Effects tutorials. -
Particle illusion from recollection can do some nice muzzle flashes.
Simple way is to draw some overlay frames with a paint program. Photoshop makes this easy using layers for positional registration and opacity to build the flash + create smoke.
http://www.kiva.org/about -
Go to www.artbeats.com and type "gun" into the search box.
Scroll down the results page a little and you'll see a load of stock footage shot on blue / green backgrounds for compositing.
They're not cheap, but then how long is it going to take you to do something as good and will you get close to it looking the same? Probably worth the expense...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hey guys, I appreciate the help so far...I was looking at artbeats, and if I had a higher budget, then I would get my hands on that stock footage.
I will admit that I know jack about photoshop and other art programs, what about basic tutorials?the fat man is back!! -
Another nice free resource for stock footage.
http://www.detonationfilms.com/free_stuff.htm"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Good call!!!Originally Posted by Safesurfer
I knew there was another one and that it was free, but I couldn't remember it / find it!There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 06:02 -
Problem with CS4 Premier Pro
By Devilish Me in forum EditingReplies: 4Last Post: 12th Mar 2009, 18:06 -
Exporting HD in Premier Pro
By videopetur in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 5th Jan 2009, 15:20 -
Using maya 8.5 with premier pro
By vipertongn in forum EditingReplies: 5Last Post: 8th Jul 2007, 03:29
