  1. Hi,
    Does anyone know (or have a link) how each of the main 4 US Networks broadcast their OTA HDTV? I know ABC & Fox use 720p, and CBS & NBC use 1080i - but how do their bitrates differ? I saw some captured shows, and seems Fox averages much smaller filesize for a 44 min drama, compared to the others!?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by MarkGrigsby
    Hi,
    ABC 720p
    CBS 1080i
    FOX 720p or sometimes 480i (4:3), 480p (EDTV 16:9)
    NBC 1080i
    PBS 1080i or 480i/480p (EDTV-16:9) often
    UPN 1080i
    WB ?
    Note: 720p and 1080i are always 16:9
    Note: most of the day, these stations transmit upscaled 4:3 SDTV from NTSC.
    Note: others note that the DTV service is in parallel to normal NTSC analog broadcasts.
    Bandwidths vary locally. HDTV only would be 19Mb/s (1080i or 720p) but many stations also transmit a 480i SDTV channel (usually a conversion of their NTSC service) as well resulting in ~3-4Mb/s SDTV + 15-16Mb/s for HDTV.
    Cable HD also varies locally by the condition of their cable infrastructure. Modern systems will use 20-25Mb/s, older systems will offer fewer channels and/or lower bitrates.
    DBS is in the process of converting from miserable HD bitrates to an all new MPeg4 based 4-8Mb/s standard that will match OTA ATSC in quality with half the bandwidth per channel.
    http://www.kiva.org/about
  3. Thanks! Is there any way to find out the bitrates of a particular local station? Also, I heard something about Fox being multiplexed differently to the others - does that make sense, or am I mis-remembering something?!
  4. Member edDV's Avatar
    Mar 2004
    Fox started their DTV service at 480p. Sports coverage introduced ABC type 720p60. Now most national FOX HD is 720p just like ABC.
    Apr 2002
    In front of my monitor
    But oddly enough, Fox's bitrate (assuming this week's Prison Break is typical) is only 9.5mbps... a one hour episode actually fits on a DVD-R once the commercials are removed, though the 1280x720 resolution would cause an error message on a standard DVD player.
    This is with no subchannels on a Fox O&O station.
  6. Member edDV's Avatar
    Mar 2004
    Individual TV stations are free to do what they want with bitrate. Minimum DTV requirement is to send one SD signal on the n.1 channel @ ~2-6Mb/s. The rest of the 19Mb/s could be used to send additional channels or even data if they wish.
  7. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    Call your local station during regular business hours and ask for the 'Chief Engineer' or 'Director of Engineering.'
