Hello everyone,
Please help me with the fundamentals of video editing. I have learned a lot of good things about video editing from this forum, but I am not able to connect the dots. Probably I have not understood the basics of it. Here is what I have learned to do:
Capture/copy the video from my Panasonic PVGS 15 miniDV camcorder to the laptop through a firewire 1394a cable. I use WinDV to capture/copy the video to my hard drive in the DV-avi format.
Once the video has been copied to the hard drive, I use TmpGenc to encode it to mpeg1 so as to make a VCD out of it. I follow the steps given in this link https://www.videohelp.com/tmpgenc.htm
Now my question is:
When should I edit (add flavor/spice up) my video (delete scenes, add background music, create chapters, add titles, etc.). Should I do it after I have copied it to my hard drive, or should I do it after I encode the video.
Can anyone please post the order that I can follow for making the video. Also if possible can anyone please list the names of the softwares/applications next to the task.
For example:
Step1. Capturing from miniDV camcorder to hard drive using firewire cable - WinDV, DVIO.....
Step2. Encoding from DV-avi to mpeg1 or mpeg2 - TmpGenc, MainConcept....
Your help will be highly appreciated.
Thanks in advance.
Results 1 to 15 of 15
I would think that the editing would be on the AVI to gain the highest quality. Then encode the file.
Yes, editing should be done in the DV-AVI format before encoding. There are many options as to which software to use and each have their advantages. I personally use WinDV to "capture", VirtualDub and AviSynth and sometimes Ulead Video Studio for editing. Then I use TMPGEnc to encode to mpeg1 or QuEnc to encode to mpeg2.
Buy My Books -
Why VCD? that is an obsolete MPeg1 format that takes your 720x480 (not really) video down to 352x240/288 at half the temporal resolution (30/25 vs 60/50). For camcorder acquired video this seems silly unless there is a compelling reason for CDR.
2. Edit DV (many solutions)
3. Save the DV edited material at full quality back to DV tape (highest quality).
4a. Encode and author for DVD (very good quality).
4b. Encode and author for VCD (very low quality) as an alternative.
Originally Posted by technextRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks,
GilbyGood, gadgetguy & edDV for your comments.
Thanks. -
Can't you afford a DVD recorder? They are very cheap now.Recommends: Kiva.org - Loans that change lives.
But being a student, my budget is a little tight -
Then I suggest holding off on this work until you have money for the DVD burner. You can buy a normal internal drive for about $40 off newegg.com, and then build your own external USB or firewire enclosure rather cheap ($30?).
@ technext:
I do pretty much similar stuff to you (holidays and friends weddings to DVD, not VCD). Here's what I use:
Transfer: WinDV (free)
Edit: Adobe Premiere Pro v1.5.1 - there are other tools, look in "Advanced Editing" in the "Tools" section.
Encode: TMPGEnc Plus (US$37). Good encoder to MPEG2 (used for DVDs), but not the fastest. There are others that are considered in the top bracekt: Canopus Procoder, Mainconcept MPEG Encoder, Cinemacraft Encoder
Author: TMPGEnc DVD Author (US$70). A good place to start if you're not familiar with authoring, but can be restrictive if you want to be more creative. That said, has good menus.
Burn: TDA has a burn engine that won't let you burn faster than the disc is rated etc. But Nero will do the job too.
Enjoy: Sit back and watch your DVD whilst enjoying a fridge full of beer...
If it's any consolation, I went through similar pains while I was learning the pitfalls and tricks to getting DV to DVD. But, I persevered and am really pleased I did.
Stick with it and you'll get there. Feel free to ask questions, especially as it sounds like we've got similar goals.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by daamonWant my help? Ask here! (not via PM!)
@ lordsmurf: Good point. I did read that (s)he's a student, but had forgotten this by the time I'd pasted the text... D'Oh!
@ technext: By way of making amends, there's also the following which sound like they'll fit the bill (in no particular order), and are either free or inexpensive:
1) Avid Free DV
2) Zwei-stein
3) AviTricks
4) Vegas Movie Studio
5) Ulead Videostudio
6) Pinnacle Studio
There are loads more, but these are regularly mentioned in these forums. Have a read, trial a few and make your decision. I'd be inclined to give Adobe Premiere Elements, Avid Free DV and Vegas Movie Studio a go first. But it's your call...
Good luck and enjoy...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
lordsmurf,
thanks for your input !
daamon,
I am very pleased to see your descriptive reply. This is exactly what I was looking for. This will make life easier for me.
It does seem like we both are in the same boat
Thanks a bunch !
I have a couple of quick questions for you guys:
1. When I capture the video from miniDV tape using WinDV through firewire cable, it says '0 frames dropped'. Does that mean I am getting the exact same quality what the camera is recording ?
2. Does the quality of the already captured DV-avi video improve if I encode it into mpeg2 (DVD format) ?
Thanks in advance. -
Qualified students can get major discounts on video editing/authoring software.
See
http://www.academicsuperstore.com/?page=Category&category_id=244293&TOKEN=dda7c5d63d6b...d749464e8d851e
all products
http://www.academicsuperstore.com/?page=Category&category_id=244304Recommends: Kiva.org - Loans that change lives.
2. Does the quality of the already captured DV-avi video improve if I encode it into mpeg2 (DVD format) ?"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
Need help cutting out video segments and making one video with them
By darkcyber in forum DVD RippingReplies: 2Last Post: 23rd May 2011, 17:26 -
Need tutorial for video making
By mazeer in forum EditingReplies: 1Last Post: 5th Jan 2011, 06:32 -
Making video with avisynth
By ingeralhaosului in forum EditingReplies: 2Last Post: 24th Nov 2009, 06:08 -
making a video CD
By d_razaq in forum Newbie / General discussionsReplies: 8Last Post: 21st Sep 2007, 22:41 -
Making Plasma Video
By MI6 in forum EditingReplies: 0Last Post: 28th Jul 2007, 07:07
