Hi, I am trying to use TMPEGEnc DVD author to create a DVD of an mpeg file I creates. I had a divx file with 5.1 ac3 sound and I ripped the ac3 from the divx and converted the divx to m2v format. Now I know that TMPEGEnc DVD Author can use ac3 files as I have used them before (2 channel ones admittedly) and I have never tried it with 5.1 ac3 files. When I input the m2v file it is accepted, however when I try to select the ac3 for the audio it I get an "Illegal audio format" error. I have checked the ac3 file for errors and there are none. It is a 48000 384kbps file. Why can't Tmpegenc DVD Author see it as a valid ac3 file ?
I recently downloaded a XviD AVI file with muxed 5.1 AC-3 and I used VirtualDubMod to demux the AC-3 but I had to run the AC-3 file through AC3Fix in order to get it to work with TMPGEnc DVD Author.Originally Posted by Baldrick
So in other words I am just trying to confirm what Baldrick is saying.
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 01:05 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 21:33 -
TMPGEnc DVD Author-sound?
By Mållgan in forum Authoring (DVD)Replies: 2Last Post: 14th Apr 2009, 06:51 -
TMpegEnc DVD Author won't fill a 4.7 GB DVD
By jagojon3 in forum Authoring (DVD)Replies: 12Last Post: 29th Dec 2008, 19:32 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23
