I wonder if it's possible when creating video from JPG pictures (slide show mixed with music) in VEGAS 6, to add automatic transitions ( differend type) between each picture. It is possible working with PINNACLE STUDIO 8 with function "RIPPLE" but there is no option working with two video.
Somebody will suggest using some other programs like MEMORIES ON TV, but my idea is to put pictures on one video in time line ( pictures) and puting other video in time line working like mask ( flying baloons or something), together mixed with music. My main reason working with two video ( pictures plus mask ) is to eliminate black screen when vertical pictures appears.
For example, when working with lot of pictures (400-500), adding different transitions between each picture is crazy.
Regards.
QUALITY HAS A NAME
You can create automatic cross fades so that when you drop two clips on the same video timeline and overlap them you don't have to manually set the fade. You can then change this transition to any other type of transition either manually, or with the change all selected events option (all this is in the help files, check them out for details), but I cannot see any way to change the type of transition automatically in a random type manner. I am sure you could script something to do it, although how will require some reading on your part.
Read my blog here.
How to control transition length in Vegas Pro 10?
By gutterboy in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
What's with the transition in Vegas....
By Abas-Avara in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2009, 13:52 -
Vegas 8 - Transition help
By stantheman1976 in forum EditingReplies: 14Last Post: 30th Aug 2008, 07:29 -
Using Pinnacle transition FX in Vegas?
By NoRulez in forum EditingReplies: 0Last Post: 9th Sep 2007, 12:59 -
using a book page turning transition in vegas?
By Rudyard in forum EditingReplies: 1Last Post: 11th May 2007, 04:06
