There are only like 7 or so backgrounds in TMPGEnc Dvd Author and I haven't seen or been able to find a way to add my own background image. Is it possible to do this?
What We Do In Life, Echoes In Eternity....
yep. this is for 1.6, but I assume it holds for other versions. Click on Create Menu, the click on the background. You should then be able to open a file. This can be a still image file, or a video asset, inwhich case you can use the slider to select the frame you want as the background.
Read my blog here.
Great, thanks guns1inger
TMPGENc Authoring Works 4: Menu crashes after I add background music
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 11th Aug 2011, 15:32 -
How do you add menu links in TMPGEnc Authoring Works 4
By philled in forum Authoring (DVD)Replies: 1Last Post: 27th Nov 2009, 09:47 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49 -
How to add background music?
By coody in forum AudioReplies: 2Last Post: 25th Sep 2008, 16:04 -
DVD Lab, Is it possible to add video to background on the menu
By frozenwind in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2007, 10:09
