I have read the manual for my MOBO many times. It mentions little to nothing about specifics of HDDs. I have went over and over the information included in the manuals regarding HDDs. The link you gave me isn't loading, but nevertheless, I have the manual and it doesn't talk into detail about the HDDs. No manual came w/ the HDDs.
[EDIT]I found out how to create a partition via Disk Management!![]()
[/EDIT]
I really am trying here, i'm not just looking for you guys to give me all the answers, all though it may seem that way.
Thanks.
Results 31 to 40 of 40
I know you're trying.....I'm trying to help you out....I know how frustrating it can be when you can't get something to work correctly....
The link I provided is fine it takes long to load because you have dialup.
Hopefully SP2 will solve your problems.
Glad to hear you found out how to make a partition! -
That link is the same exact manual that came w/ the MOBO. It doesn't tell crap about HDDs.
I'm hoping that it'll all work out w/ SP2, if not, i'm out of ideas. -
I thought you figured out how to partition that 200gb hard drive.
I did, but we were trying to figure out how to solve the 137GB barrier problem at the time. I think everything is cool now, just waiting on a disc in the mail.
BTW, you think I should run that big drive enabler before I partition and format the 200GB drive or after? Or run it after I partition but before format? I guess I can just experiment, just figured i'd ask.
Thanks -
I gave up on having a single partition on my 200gig when I couldn't get a bios upgrade for my Asus board. It was much easier just to create 2 partitions. Helps to keep stuff separated anyway. It's no big deal.
Originally Posted by chewie8008
Oh, just for the record, after installing SP2, big drive enabler worked and I got 189GB from the drive.
Thanks for all the help!!! -
I had your same problem when I first got my 200Gig WD drive. Would only recognize 127 Gigs. Then I slipstreamed my XP disk with SP2, reinstalled, and it saw my full 200 Gigs.
If you have a standalone XP disk, just boot from the disk to wipe your drive and reset your partition. If you want another OS on your drive, all you do is created a dual-boot setup by creating two partitions, then installing the older first and the newer second. At bootup you can choose between either one you want to use. I do it all the time.
Legit Converter?
By JRoo in forum Video ConversionReplies: 8Last Post: 26th Aug 2010, 05:41 -
DVD ripping goes legit with RealDVD
By drjtech in forum Latest Video NewsReplies: 28Last Post: 3rd Mar 2010, 19:06 -
verifying sectors on a legit dvd
By Ryan in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2009, 17:20 -
is this site legit???
By glockjs in forum ComputerReplies: 6Last Post: 16th Jan 2009, 08:18 -
Registry Cleaner for WinXP Pro...
By retroborg in forum ComputerReplies: 5Last Post: 17th Oct 2008, 10:53
