My question is this.......I have used the Bitrate calculator and 2pass to utilize the entire disk and the pictures seem to look better. Now I am wondering if changing the frame size from 352x240 to 480x480 will make a visual difference when I play it on my DVD player. I am using tmg to convert avi-mpg and nero (DEMO) to burn (the demo version only has the vcd option). I would appreciate any help you can lend me
I am asking because i am not at home so i wanted to get feedback before i went home and tried it
generally high resolutions only benifit from enough bandwidth.. 480x480 benifits from a 1800 kb/s or better bitrate (video). any lower and you probably can just stick with 352x240.. if you up the resolution and not the bitrate it can (sometimes) end up looking worse - imo
Yep. Think of bitrate as money, and your framesize as number of people attending your party...
The party will be better for more people if you spend more, but the more you spend, the less room you have to party.
irc.webmaster.com port 6667 #DDR
Frame Size
By kamranj in forum Newbie / General discussionsReplies: 18Last Post: 9th Jan 2011, 18:59 -
Upconverting SD to HD frame size...
By bkelly36 in forum MacReplies: 3Last Post: 24th Oct 2010, 17:31 -
Frame Size. What effect does it have?
By happydog500 in forum Capturing and VCRReplies: 7Last Post: 12th Mar 2009, 00:21 -
Video frame size
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2008, 19:35 -
How to alter frame size?
By elite123 in forum Newbie / General discussionsReplies: 4Last Post: 20th Aug 2007, 18:43
