  1. Hello one and all,
    Got a quick question on menu's. Typically, I use Tmpg to author my dvd's but have run into a problem with my most recent disk. I have tried looking through the program and trying different things but it doesnt seem to be able to do this.
    Here is the situation:
    I have 4 "movies" and a bunch of "extras" that i wish to put on a dvd. All told, its well less than 2 hours of material and approximately 3.3gig worth of data. What I would like to do is place all 4 "movies" each with their own menu and then add ALL "extras" in a separate meny entry, and then having to click on the "extras" menu to get to all the individual extras files. Ie: if i was using Windows explorer, the equivalent would be placing 4 files into one directory and then placing a few more into a subdirectory.
    Can this be done with Tmpg? Im thinking it cant but I have been wrong before. If not, can someone recommend a program that would enable me to do this?
    Thank you very much in advance.
    LG
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Using TDA -
    Create new project
    1st movie - Add file/choose MPEG/add chapters (if required)
    Add new track
    2nd - movie Add file/choose MPEG/add chapters
    Add new track
    3rd - movie Add file/choose MPEG/add chapters
    Add new track
    4th movie - Add file/choose MPEG/add chapters
    Add new track
    Inport all your extra's into the same track.
    He's a liar and a murderer, and I say that with all due respect.
  3. Member daamon's Avatar
    Melbourne, Oz
    What steveryan suggested will work, but may not exactly fit what you're after (I think).
    It sounds like you want a menu to acces the film folder, then a sub-menu to play the film or access the extras, and then chapters in the film and access to the extras seperately. TMPGEnc DVD Author can't do this.
    steveryan's suggestion will give you a main menu to select each film, and then the film and its extras will all be in the chapters.
    DVDLab Pro should do what you want, but it's more complicated than TDA - be prepared to do a lot of reading, learning and experimenting before getting what you want.
    A guide for DVDLab: www.videohelp.com/forum/viewtopic.php?t=220092
    Good luck...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  4. steveryan,
    What you suggested worked great. Thank you very much
    LG
