2 issues
1. I convert the 2 bin and cue files to DVD but when i come to play the resultant DVD it stops at the end of the first half - the second half is there but will not automatically move on to it - I can fix it by running the resultant output through DVDShrink but can you tell me what is wrong
2. Every time I try to convert an AVI using SVCD2DVD2 it will go for so long then stop saying ffmpeg encountered a problem ad forced to clse then it outputs about 6 minutes in DVD format. The other alternative is that it just crashes my whole machine
Can you help
1. I suspect you have two titlesets and no menu. If you use Quick DVD, make sure you have both bins in the same folder, otherwise setup the DVD layout manually.
2. Have a look at https://www.videohelp.com/forum/viewtopic.php?t=265207&highlight=cpu and the cited threads. If this is not the case for you please send me your log & I will try things at my end.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
